No power to starter. Weird.
Old Jul 17, 2014 | 11:31 AM
82ztwenty8guy's Avatar
I have a 1982 z28 camaro automatic with a 350 carbureted engine. I just put on a new exhaust a couple years ago and lost interest after that. I picked it back up about a week ago and i cant get the starter to activate. The battery, alternator, and starter are all fine and have been tested. The wire that gives the starter power at the small bolt to the right does not have power when the negative terminal is hooked up to the battery but does have power when the negative is off the battery. Does anyone have any idea what is going on?
Old Jul 17, 2014 | 07:06 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: No power to starter. Weird.
You're testing it wrong. Why would you check for voltage with the negative cable disconnected?
Having said that, which small wire are you talking about? Wire color? Post a picture? Are you sure you've got all of the wires connected at the starter? It is amazing common to forget to connect all the wires at the starter.
Old Jul 18, 2014 | 12:25 PM
I ended up figuring it out. Somehow the pirple ignition wire under yhe driverside dash came apart and all we did was reconnect it. I wa way back by the firewall which is why i didnt catch it in the first place. Thanks for the tips tho
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
5spdcamaro
Aug 28, 2015 02:12 AM
sailtexas186548
Aug 24, 2015 10:11 PM
CORV3TT3
Aug 23, 2015 11:26 AM
