swapping to vortec looking for wiring diagrams
Old Jul 23, 2014 | 09:26 AM
Sinfulrelations's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
hello all im swapping a 96 vortec 350 into my 1983 trans am, ive already pulled the crossfire efi harness out of the car and and getting ready to start wiring up the harness for the vortec, i was wondering if anyone had the wiring diagram for the harness that comes through the firewall on the drivers side,(cant remember what its called right now) thanks in advance!
Old Jul 23, 2014 | 07:39 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: swapping to vortec looking for wiring diagrams
I believe that you are asking for the C100 connector pin out?
http://www.austinthirdgen.org/mkport..._1992_C100.gif
From our sister site:
http://www.austinthirdgen.org/index.php?pid=19
Old Jul 25, 2014 | 09:30 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Do NOT follow that C100 diagram above !! It's from a 90+ ThirdGen and NOT compatible with your 83. ( Power distribution, Reverse lights, & wiper wires are wrong - just to name a few. )
Here is the C100 from an 82,.... your 83 should be the same; Compare your C100 to this diagram FIRST to be SURE !!
You're gonna' want to leave the C100 pretty much intact in your car and add the vortec harness as a 'stand alone" system by feeding it power and ground where needed. Might need to mess with the Alternator wire & you might need to tap into @ C100for the Tach wire since the Gen 1 distrib is not going to be used.
82-83 Wiper system is not compatible with any other year,.. so using any C100 harness other than a harness from the 82-83 Thirdgens will cause you some wiper motor nightmares !
Old Jul 25, 2014 | 11:29 AM
Tibo's Avatar
Car: 1991 Z28 Vert
My fault, I saw 92 in his profile and pulled it for that.
midge54
Sep 2, 2020 07:13 PM
89GTAOz
May 16, 2020 09:31 AM
Fast355
Dec 2, 2016 06:33 PM
Caspar
Jun 19, 2016 11:19 PM
jharrison5
Aug 19, 2015 05:53 PM
