Power at battery ground, non at starter....
Old Jul 27, 2014 | 05:05 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
So I used a multimeter to test the battery since the car has no power to anything. It shows that there was 12V when I touched the negative battery cable (at the alt bracket) to another surface but when doing the battery cable at the starter and grounding it it says zero. And yes the cables are the battery right and the battery is fine when by itself, ever did it with another battery and its the same. What is going on?
Old Jul 27, 2014 | 06:08 PM
Re: Power at battery ground, non at starter....
Well I assume the car is not grounded. Im not sure what is wrong with the grounds. I painted the engine and bay but I would assume power could transmit throught the bolts and threads. I cleaned off the bolt location for the negative battery cable and the firewall ground but still same problem. I have no idea what to do.
5.7 91 tpi btw
Old Jul 27, 2014 | 06:48 PM
Joe Tag's Avatar
Check for continuity between the battery neg and the end of the ground cable, then the block, then body ground.
Old Jul 27, 2014 | 07:49 PM
Turns out this guy who had it before jerryrigged something on the positive cable which was not correctly done and i jiggled it and it fixed itself. Thanks anyways.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
sailtexas186548
Aug 24, 2015 10:11 PM
justin57
Aug 20, 2015 07:05 PM
