1983 Trans Am C100 Diagram and instrument panel pinouts
Old Jul 30, 2014 | 07:08 PM
transformula87's Avatar
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
I couldn't find the proper C100 diagram for my 1983 Firebird Trans Am (daytona pace car) with the LU5 Crossfire, Automatic. I am in the process of a LSx swap in my car, and I had the whole cars wiring harness laid out in my basement. So I traced EVERY wire and edited another diagram for the C100 connector and made a diagram for the Instrument panel, in case anyone else is looking for them.
Should be useful if you are trying to do a swap and are keeping the stock gauges. Or for anyone trying to find where a wire goes in this harness.
I am not responsible for any electrical issues with your car, and this is only a guide. This SHOULD work between 1982-1984 and possibly other years, but I can NOT guarantee that.
Old Aug 1, 2014 | 07:10 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 1983 Trans Am C100 Diagram and instrument panel pinouts
82-84 carb cars are for the most part, the same. CFI and berlinetta digital units are unique to an extent, but all of the swap important stuff is in the same spots. You also need the C207 pinout
This info is posted in the additional info thread of the LS1 swap sticky
Old Jun 10, 2017 | 06:00 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Bumping this old thread, sorry!!
I have a 1983 with the V6. I'm trying to find this same pinout picture for that motor as the pinout appears different than the CFI car.
For example, I need to identify wire E4 which is tan/white... and that isn't used in that diagram!
Attached Thumbnails 1983 Trans Am C100 Diagram and instrument panel pinouts-18951087_1461806877199511_1850534119585078898_n.jpg
Old Nov 24, 2017 | 08:14 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I'd like to make just one correction.
The wire color for the Choke Indicator (pin 5 on C1) is light blue (not Brown) and there are 2 wires coming out of that pin...
Old Nov 24, 2017 | 08:52 PM
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
Please do not take this as argumentative, but do you have the same model car? Mine was absolutely a brown wire. Just curious what, if any, differences there was in the car models.
Either way, good to have the information updated. I know when I was doing my c100 (and other connections) that no books showed exactly how my 83 dt500 was setup. Some were very close, but for whatever reason that car was differently wired from the factory.
Old Nov 24, 2017 | 10:22 PM
T.L.'s Avatar
Well, my car is carbed and the other car I looked at was carbed. Your diagram is for the crossfire, right? Maybe that's the difference. I don't know.
By the way, I appreciate your C100 diagram...
Old Nov 25, 2017 | 05:35 AM
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
Yeah mine was originally the Crossfire LU5. I would assume it didn't actually function anyways, seeing as it didn't have a choke, but it was wired for it.
Anyways, good information to have for someone looking later on.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
Exxon Limited
Aug 9, 2015 08:13 PM
