Removing ECM, Couple Questions
Old Aug 5, 2014 | 05:55 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
As the title says, On my 88 GTA.....
There's a dark green wire going from the AC clutch to the ECM, Why is this wire ran to the ECM and what do I do with it to remove the ECM ?
Thanks for your time !
Old Aug 6, 2014 | 11:18 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Removing ECM, Couple Questions
The ecm grounds the compressor clutch to turn it on.
What do you do with it to remove the ecm? Unplug it like the rest of the wires going to the ecm. Maybe I'm not understanding your question?
Old Aug 7, 2014 | 11:05 AM
Restrorob's Avatar
Car: 88 GTA
Thanks Rockguy,
Got it sorted out....
Old Aug 7, 2014 | 11:38 AM
Joe Tag's Avatar
[quote=Rockguy;5802424]The ecm grounds the compressor clutch to turn it on. quote]
Old Aug 7, 2014 | 12:00 PM
Joe Tag's Avatar
Possibly a convoluted way to turn on the aux fan with the compressor, but you could have that wire to the ECM trip a relay that sends a ground to the aux fan relay.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
