Wiring Electric Fan without ECM
Car: 1988 Pontiac Firebird
Engine: LO3 5.0 (305) TBI
I think i may have accidentally posted this in the wrong section before this but I have an 88 Firebird Vin E TBI with the L03 5.0L; however I am swapping over to a new carbed 350 and I understand that the stock electric fan is controlled by the ecm. How will I get the fan to work properly without the ecm? I'm a little confused when it comes to the wiring. Sorry if this is basic question but I'm totally lost. Any help would be appreciated. Thanks.
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Wiring Electric Fan without ECM
I kept mine too, I just wired the ground side of the relay up to a toggle switch inside the car.
Single fan is controlled independently of the ECM by the coolant fan switch. Keep everything to the fan harness as it is and you should be fine. Adding a switch is not recommended unless it is to trip the relay to turn the fan on.
Thanks for the help! I have another question about wiring an hei distributor in place of the old ecm distributor. How exactly do I need to rewire the stock tachometer line to the fit the new hei distributor?
eightsixseven
Dec 16, 2024 01:50 PM
