blower vent addition
Old Aug 16, 2014 | 05:04 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Hey everyone... Im looking at adding more blower vents into my car.. I have an 89 rs and it does not have any in the sides of the dash... My question is is there the duct work back there. I can get all the vents to put in there spots in the dash. Just dont want to pull stuff apart if the rest of the system is not there
Old Aug 17, 2014 | 01:38 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: blower vent addition
The rest of the system is NOT there; You can't just cut a hole and add vents
The AC airbox and the AC delete airbox are different. So is the dash housing itself. At A MINIMUM You would need to remove your non-AC dash housing ( with the non-AC airbox on back), Then install the dash housing from an AC car (with AC Air box, Left/Right ducts ) on the back.
Old Aug 17, 2014 | 07:06 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Best bet is to stop by a pull your parts place and dig into one. Then you'll see what's involved, get some experience, and will be able to get everything you'll need.
Old Aug 17, 2014 | 08:02 AM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Ok thank u
Pac J
May 17, 2020 10:44 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
buckeyecelt
Sep 24, 2015 05:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
