88 Iroc Z 350 turns off then won't turn on.
Old Sep 8, 2014 | 07:41 PM
DTownIrocZ's Avatar
Car: 88 Camaro IROC-Z 350 L98
Engine: 350 L98
Transmission: 700R
Axle/Gears: Stock
Hello forum! This is my first post btw. I'm having a issue with my iroc. Just to let you know I did a search and found a few matching posts but no resolution. Here's the example. I drove about 30 miles after work to home. I stopped to get gas and once I'm done filling up I cannot start the car. The fuel pump primes and dash lights come on but will not turn over. No click no nothing. I called my wife to come and give me a jump since that's the only thing I could think of and bam! Fires right up. I guess I could just change the starter for preventative maintenance but is there anything I should check out. Battery seems good. Cables look good as well.
Old Sep 8, 2014 | 08:59 PM
Ta Re Ser's Avatar
Car: 88 GTA Ta
Engine: 5.7 TPI
Re: 88 Iroc Z 350 turns off then won't turn on.
Im having the same problem but I think its the vats system. I wait 5 minutes and she'll start. My issue though imdomt get fuel prime or starter click.
Old Sep 9, 2014 | 07:06 PM
DTownIrocZ's Avatar
Engine: 350 L98
Transmission: 700R
Axle/Gears: Stock
It happened to me one other time. I let it set for about 30 minutes and then it cranked. I got to figure this out!
Omega
Oct 1, 2015 02:20 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
BrianI
Aug 9, 2015 11:52 AM
