holley hp efi help
Old Sep 11, 2014 | 04:13 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
holley hp efi help
i need info on where to connect the white and the yellow wires out of the loose wires from the main harness. yellow is rpm output but I'm using a computer controlled small cap. holley diagram doesn't show any yellow wire connected anywhere. Should i cap it and tuck it away?
and secondly the all white wire. i think its for msd type ignition box, im not using a cd box so should i cap and tuck this too?
thanks for any help
Old Sep 11, 2014 | 05:35 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: holley hp efi help
I tried looking this up, but couldn't find anything on it either. I see you posted in the Holley forum. Don't worry, Danny is great and I'm sure he or others will reply there quickly. I would suggest you go back and update your thread with what harness you have, wire colors by themselves may make it difficult for Danny to guess which one you're asking about.
Old Sep 11, 2014 | 06:27 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
ok cool thanks. ill wait for a reply on holley forum.
Old Sep 12, 2014 | 06:12 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
if using gm small cap hei (computer controlled) cap and tuck away the yellow and the white wires. you do not need them.
loose wires from holley hp efi harness for tpi.
red/white:switched 12v
red: 12v
green: fuel pump 12v.
white: do not need. cap and tuck
yellow: do not need cap and tuck
black: ground
everything else plugs into a sensor so should be self explanitory
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
dusterbd
Sep 29, 2015 08:40 AM
