Can 1992 gauge cluster work in 1988
Old Sep 25, 2014 | 03:58 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
I haven worked 350 carb ,I did a t5 swap, I need to get a speedo working since the trans has a electronic sender, and really wood like to keep a stock looking cluster even if not from the same year and I know that re wiring will be nessity
So does it fit and has anybody done this
Old Sep 26, 2014 | 07:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Can 1992 gauge cluster work in 1988
Swap out the sender in the trans for the mechanical version (speedo sleeve and driven gear) and you should be good to good.
The 92 cluster is electronic and, of course, is a different shape altogether, so fitment would require major mods to your dash.
JamesC
Old Sep 26, 2014 | 08:54 PM
camarofvr's Avatar
Car: 87 Camaro Z28
Engine: TPI 350 bored .030 over
I tried doing that with a unit from a salvage yard and some things worked and some didn't. i think some of the circuits may be different but the cluster may have just been bad. And yeah the dash won't really look right and I'm not sure the side panels will fit either so it may not be worth the effort even though it's a much more attractive cluster. Anyone else tried?
Old Sep 27, 2014 | 06:42 AM
JamesC's Avatar
Swapping, as I suggest, only affects the speedo, nothing else.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
