HELP!!!!!!!!!!!!!!!!!!!!!!
Old Oct 8, 2014 | 03:42 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Just came it from the garage cant get the tach to work yet here's what I did no computer car no tach filter just 1 wire from the cowl hook up at d6 a white wire from there to the msd box an it still doesn't work car is a 87 iroc with carb. Thanks.
Old Oct 8, 2014 | 04:00 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: HELP!!!!!!!!!!!!!!!!!!!!!!
You may need a MSD tach filter. This pic is how I wired mine it may help
Old Oct 8, 2014 | 04:44 PM
mr z28's Avatar
I have everything a msd dist coil an box 6al . according to msd book I shouldn't need nothing. lost
Old Oct 12, 2014 | 07:50 PM
DanzigEx's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Are you using the Stock Tachometer or an After-market tach? Does the tach stay low, read high, or some where in-between?
Going off of what Midias said, and considering our charging systems the information here should be usefull (hopefully).
That link discusses the tach adapter, and gives a part number for use.
This is the Part discussed in the thread.
If the links don't work, here are the direct links:
http://www.msdignition.com/forum/showthread.php?t=2168
Part
http://www.msdignition.com/Products/...c_Trigger.aspx
Last edited by DanzigEx; Oct 12, 2014 at 08:08 PM. Reason: Left out some information
