help figuring out these wires...
Car: 1989 IROC-Z
Engine: 5.7
Im having a code 34 problem on my iroc so tonight I decided to pull down the kick panel and make sure all the connectors and secured in the ecm just for piece of mind, and the first thing I see dangling there is this plug and these 3 cut wires. I dont think they are related to the code 34 maf problem but it would be nice to know what I got here...thanks!
Car: 1989 IROC-Z
Engine: 5.7
Re: help figuring out these wires...
Theres also this one thats intresting.. it gets power just can't figure out where its supposed to go
Car: 88 GTA Notchback
Axle/Gears: don't know
Car: 88 iroc
Engine: 350 4-bolt main 010 bored .040 over
Transmission: t-5 manual
it could also be the wire that you unplug to set your base timing for your distributor.
Car: 1989 IROC-Z
Engine: 5.7
That tan wire is still tucked by the fender, and the blower still works. Its puzzling cause ive looked everywhere and cant find for the life of me where it plugs into!
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
First pic shows power antenna relay wires,.... Second pic appears to be the power wire for the hood lamp.
Car: 1989 IROC-Z
Engine: 5.7
Ahh that makes since! In the second pic above the unplugged red wire there is another red wire with a connector that looks like its been fried...does anyone have an idea of what that goes too? Last question about the wiring thanks guys!
RedLeader289
May 28, 2019 01:47 PM
