Headlight switch ?
Old Nov 4, 2014 | 08:23 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
Headlight switch ?
How do you. Remove the headlight switch on 89 firebird thanks
Old Nov 9, 2014 | 02:02 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Headlight switch ?
You will have to remove the plastic bit that goes over the instrument cluster and the switch assembly. To do this, remove the 7mm bolts along the top edge which hold it to the dash. Then drop the panel under the steering column, there should be two plastic caps covering torx screws. I'm not sure if just removing the two under the caps will suffice or if you need to remove the three torx on the bottom edge of the panel as well. Also remove the panel that houses the fog light/defrost/trunk release switches by removing two bolts from the underside of it. It has some clips so you will have to pull it off. Then you should be able to remove the bolts from the bottom of the main plastic piece that covers the instrument cluster and the switch assembly. It should be free now so you can remove it. This should expose some screws which hold the switch assembly down. Remove those screws, and the headlight switch and dimmer switch assembly should pull off. You can then use a small flathead screwdriver to pry the tabs out on the switch enough to get it wiggled out. I forget if it's held on by screws to the back or not.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
