power antenna question
Old Nov 15, 2014 | 09:34 PM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
the power antenna on my 88 GTA does not work, the motor works fine but the nylon cable is in pieces. i attempted to fix it by JB welding in a new steel cable, sadly it went down once and the jb weld did not work.... so i have a question, is there a power antenna that will work to replace the whole thing or should i just buy the replacement cord that is meant for the antenna. i would rather not put in a solid antenna as i want to keep the car original-ish. any recommendations guys and gals?
Old Nov 15, 2014 | 09:57 PM
vorteciroc's Avatar
Top Answer: 1
Re: power antenna question
FIRST OFF: I hate power electric antennas altogether... All though the lovely old antenna assemblies installed in our cars really were not all that grand even when NEW back in their day. The new/ remanufactured/ replacement assemblies are even worse. I'm sure someone here has replaced their antenna assembly with decent results from one of the sponsors... I'd search through the sponsors and go that route. :-D
Old Nov 19, 2014 | 11:19 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hawks Third Gen, thirdgen ranch, Classic Industries and Year One all sell the "replacement Mast" kits for the power antennas. You might also find one in a JY that's still in good shape. You can also post down in the classified section of this website, that's how I found my replacement antenna. Also look on Ebay as well. They're out there to be had.
Old Nov 19, 2014 | 11:23 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Have you read all 4 pages of this?
https://www.thirdgen.org/forums/hist...ld-thread.html
Old Nov 19, 2014 | 10:24 PM
ssj2link's Avatar
Engine: 5.7/5.0
yeah i read that i guess im going to order the original replacement piece with the nylon, im just afraid it will break again. i can get it from hawks and also this site:
http://www.antennamastsrus.com/GM/Po...01988-1992.htm
its not too expensive, i just hope it will hold up.
THANKS FOR THE REPLY'S!!!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
