rear hatch defroster repair .
Car: 1986 camaro iroc z
Axle/Gears: stock
ok so winter is hitting hard and i seriously need to get my rear defroster working agian but aparently the previouse owner riped off the driver side contact strip that atachest to the window and the strut and the other side is sagging and no longer fully atached can someone help me repair this
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: rear hatch defroster repair .
I you look around on the internet you will find quite a few products to repair rear defrosters. I used the Loctite one on my suburban. There are two types, one for the grid and the other is for the tab. I'm thinking you will need both.
Axle/Gears: stock
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Your best bet might be to find a new hatch.
Street Lethal
Apr 30, 2019 12:14 PM
