Interface name/type
Old Dec 1, 2014 | 12:39 PM
NiG's Avatar
NiG
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Interface name/type
Hi
I would like to know the name of our interface (mine is a 1989 GTA):
What could this be used for? Can it be connected with a PC?
thanks
bye!
Old Dec 1, 2014 | 03:30 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Interface name/type
Hi Nick .
That is the "ALDL" port "Assembly Line Data Link" ....
And yes , with the right cable there is some data that can be taken from there . Also called "OBD1" "On Board Diagnostics 1" . This was , as the 1 specifies , the first on board system that would give trouble codes to aid in the diagnosis/repair of certain drivetrain related faults . The GREAT news is , that by jumping the correct two of those pins , you can get the check engine light to flash out any stored codes for ya . Just type PAPERCLIP into the search bar at the top of the page and you will find all kinds of descriptions of the procedure .
Have fun ...
Old Dec 1, 2014 | 05:14 PM
NiG's Avatar
NiG
Engine: 5700cc
thanks OrangeBird!
I'll check it
bye!
Old Dec 1, 2014 | 05:54 PM
F-body driver's Avatar
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
ALDL is a 12 pin connector.Just jump A & B with a paperclip and you will get trouble codes if stored.The first one should be 12. Each trouble code is repeted 3 times.
Here's an image of how ALDL looks like:
http://www.gnttype.org/images/conn.gif
Old Dec 7, 2014 | 10:56 AM
NiG's Avatar
NiG
Engine: 5700cc
thanks, but it seems I dont have any problems right now
350tbi
Apr 15, 2002 11:31 AM
jnjspdshop
Apr 12, 2002 11:03 PM
Christos
Nov 16, 2001 06:47 PM
