1982 Trans Am fuel sender wire
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
How do I disconnect the wire from the fuel sender on the tank?
The ground looks welded on, but can the sender wire be disconnected?
Thank you
Thank you
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1982 Trans Am fuel sender wire
** Only for 82-84 Thirdgens.
Climb under the rear end,... drivers side. You will see the fuel gauge wires leading from behind the rear impact bar / bumper cover to the top of the tank. There is a 2-wire plug clipped to the body in this area that can be dissconnected.
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
