interest in a stand alone, 3-speed electric fan conversion harness?
Old Jan 30, 2015 | 07:52 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
I'm thinking about taking my controller to the next step and offering an epoxy sealed control unit with weatherproof harness connectors to allow you to basically plug n play this to ANY fan or dual fan setup and have the ability to run it at 1, 2 or 3 speed fan operation. It will consist of a main IGN control, an AC override, 2 temp switches and an externally mounted resistor board that simply needs to be mounted where there is some airflow-it can even be mounted onto the fan shroud.
The epoxy is a nitrogen rich type so its basically won't ever be able to melt or catch on fire. The relay control unit has diode and resistor equipped relays (not Chinese crap either!) all with a minimum or 250,000 switching cycles at full load-so in essence, they'll last practically forever. Right now I'm looking at a cost of about $175 per unit and I'll be offering a 5 year warranty on the unit-I'm that convinced of its durability! The supplied temp switches will allow an operating temperature of 190-195 assuming you have an adequate electric fan. Thoughts? Let me know what you think-I'm in the final stages of production for this unit so input would be great!
Again, I'd like to stress that this control unit can be used with or without an ECM. Thanks!
Old Jan 9, 2016 | 11:31 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Re: interest in a stand alone, 3-speed electric fan conversion harness?
Hmm, I like this... Nice Quiet Operation on Low, Medium as a Default and High to bring Down the Operating Temp. I Like!
midge54
Sep 2, 2020 07:13 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
stalkier
Aug 21, 2015 01:54 AM
