Fuel Pump Relay Question
Old Feb 8, 2015 | 12:34 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Could it work to prime? but not start car (starting off of oil pressure) but still run car once started?
Just an recent odd issue and was thinking it was IAC (again) or Fuel Pump Relay.
Thanks for the clarification
Old Feb 17, 2015 | 04:27 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Prime Time
Yes it can and does.
When you try to start the engine the ECM energizes the pump relay, therefore if you would like to prime it manually you can install a switch to energize the relay.
You should use a momentary switch, which will make it impossible for you to accidentally leave the pump running.
The momentary switch can be used to energize a separate small relay to energize the pump relay.
You can wire the small relay to automatically turn off when you shutdown the engine VIA using a hot in run circuit as the feed for it’s coil circuit.
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
