no charging from alt
Old Feb 10, 2015 | 12:54 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
i just got a car running after sitting for 2 years or so ... runs good so far but i have not ran it much, as it will not charge ... the alt is a factory 3 wire type (87 gta 5.7 tpi) i know 2 wires should be hot all the time (from what i read) and one is switched, what i need to know before i go drop $90 on a new one (i hate to throw parts at it for no reason), is where does power to the switched wire come from, is there a fuse to it, does it come straight from the ignition switch or what?
Old Feb 10, 2015 | 05:57 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
IIRC, it should be tied into either the idiot light, or one of the switched powers to one of the relays.
Old Feb 10, 2015 | 06:31 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: no charging from alt
http://austinthirdgen.org/mkportal/m..._continued.gif
Old Feb 10, 2015 | 08:38 AM
Barlow8869's Avatar
cool, just what i needed to see ... someone took that c/h fan fuse out (i am guessing when they rewired the fan) and it looks to me like that is where it runs to ... if i can get out there after i take my son to school and go by autozone to get the heater valve i broke so it wont be pouring out coolant, i am going to give it a try ... if it works, it should be ready for a drive ... i have gotten everything else working, i think
Old Feb 10, 2015 | 12:40 PM
willexoIX's Avatar
As long as that wire wasnt disturbed you should be good to go just putting a fuse in. Though you could do a continuity test, or test for voltage at the alt on that wire with the key on once the fuse is installed.
Old Feb 10, 2015 | 02:03 PM
Barlow8869's Avatar
coudnt get to the wire, but put the fuse in, bam over 13 volts running ... but its fix one thing, find another ... bolt broken off in the intake, one for the thermostat housing ... that wont be fun at all ... get that fixed and i can start putting the plastic back up inside and her her ready for a good test drive ... i hate when things go like that, but ill take it slow and do it right ... i still have the iroc to drive for now
Old Feb 12, 2015 | 11:19 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
That's a pretty common one to snap. $40 at the machine shop fixed it.
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
