speedo light went out
Old Feb 14, 2015 | 02:04 AM
Voltz77's Avatar
Car: 85' Firebird TransAm
Engine: 305ci TPI 5.0L
Axle/Gears: Posi 9 bolt differential 3.27
I was driving home tonight from work when I noticed the left bulb on the speedo was out all the rest work fine so its hard to see anything under 50mph haha not like it matters because ill be going faster than that most of the time! Just kidding xD anyway can any of you walk through how to replace this blub im sure it cant be very difficult at all. THANKS!!!
Old Feb 14, 2015 | 10:51 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: speedo light went out
1st you have to remove the bezel and all the screws,the fog light bezel,it's more helpful if you remove the dash cover front screws also.Lower the tilt wheel all the way down,After you do that,you will see the screws that hold in the Cluster,remove them,then you pull out on the cluster(it's plugged in) just make sure you remove all the crews in the BEZEL.I'm showing the bezel to show you where the screws are.
Old Feb 26, 2015 | 02:01 PM
Voltz77's Avatar
sorry for the late reply been working like a DOG. thanks for the tips sounds simple enough, just to be sure if one of these lights go out the others still work right? I ask this to be certain I have pin pointed this issue
Old Feb 26, 2015 | 02:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yes.Don't know if you REMOVE a bulb,it might break the circuit.
Old Feb 27, 2015 | 11:25 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If you have a dead bulb,... yes.
If there is a problem with the cluster printed circuit than anything on the broken circuit will be effected. ( Example; if it's a broken ground circuit,... everything using that ground will fail. )
Old Feb 27, 2015 | 08:16 PM
Voltz77's Avatar
awesome, thanks again!
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
Omega
Aug 10, 2015 12:46 PM
