sensor at rear of intake
Old Feb 14, 2015 | 09:12 PM
vortec tpi's Avatar
Car: 1989 IROCZ
Transmission: 5 spd
Axle/Gears: 3.45? G92 Option
Been working on the 89 IROC for the last year as time permits and have got to the point of installing the intake and engine wiring. have all the wires marks to which sensor. May have forgot one at the rear of the intake. Oil sensor on side of block. Is there a different sensor in that oil port?
Old Feb 21, 2015 | 10:37 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: sensor at rear of intake
If ur talking about the one under the distributor that is for the oil sender to the guage in the car the one at the bottom is the oil pressure cut off switch if the motor lost oil pressure it will cut the fuel pump off so u dont destroy the motor
Old Feb 21, 2015 | 11:32 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The ops will would only cut power to the fp below 4psi, it will not protect your engine. It supply's power directly to the fp after the end controls the fp relay for prime.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
