Quick Q- Bird Headlight Connector
Old Feb 17, 2015 | 12:57 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
The connector for my headlight bulbs are literally falling apart. I am looking at getting the Dorman 84790 Headlight connector kit
here here
. Will this work?
Also, How are the headlight bulb wires properly routed?
Thanx in advance
Old Feb 17, 2015 | 09:02 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Quick Q- Bird Headlight Connector
I'm showing Dorman 85810 years covered 67-90 or Standard Motor Products S-526
Don't splice the wires, just depin and only swap the connectors.
Old Feb 18, 2015 | 04:01 AM
Veaceonee's Avatar
thats the thing. The actual plastic housing is good, its the pins/wires that are breaking.
Old Feb 20, 2015 | 09:27 PM
Car: 91 z28
Transmission: 4L60e
Ahh.. the wire routing question makes more sense now. I can't tell you on the routing as I simply don't know.
I would just replace the terminals (available arguably anywhere) and do something to keep the where the wire enters the terminal as straight and rigid as possible. This is the fail point of any wiring system and the fact that the motion of the light turning the connector into a "hinge" doesn't help.
Without seeing the connector, I was thinking to heat shrink each wire (and as much as the terminal as possible) where the wire enters the terminal. I don't know how far the terminal is recessed into the connector. I would then band (tape) all of the wires
together. Then add a Raychem heat shrink boot. I would then route the wire behind the light so its loose as possible without any chance of chaffing.
Raychem dealer
http://www.prowireusa.com/c-38-202a-straight.aspx
KCG
Jun 24, 2020 04:33 AM
gta892000
Aug 11, 2019 11:16 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
corey8084
Sep 17, 2015 02:56 PM
