Need headlight help
Old Feb 17, 2015 | 09:26 PM
ban1one's Avatar
Car: 1989 Trans am GTA
Axle/Gears: 4.10
Need headlight help
So im having a problem with the headlights on my 89 trans am, i put my headlights on today and the drivers side will open on its own but dosnt close and the passenger side wont open, but if its open when i turn on the lights it closes its self, any ideas?
Or does any one have a wiring diagram for the headlight motors? Thanks
Old Feb 17, 2015 | 10:56 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Need headlight help
The wiring diagram is in the 1989 Firebird Service Manual. You should own one if you plan to keep this car and especially if you plan to do the repairs yourself. www.helminc.com sells them new. They have recently started selling them on roackauto.com also. They often show up in eBay too.
As for your headlight issue, it sounds as if the headlight control module is bad. I would unplug the headlight motors and run a jumper to the opposite side motor and see if it you can create the same problem with the opposite side motor.
I normally sell the module but I'm currently out of stock. Placing an order for one on my web site will put you at the front of the line for when I do have one available.
Lon Salgren
Old Feb 18, 2015 | 09:18 PM
ban1one's Avatar
Axle/Gears: 4.10
Lon Salgren
Ill give that a try, thanks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
