help no spark
Old Feb 18, 2015 | 01:45 PM
turbotrix2004's Avatar
help no spark
i used the search feature but couldn't find a way to test anything. I have an 87 trans am gta with a 5.7 tpi engine that ran good but then sat for over a year. When i try to start to start it, it cranks over but will not start. I check for spark today and got nothing. the way i checked was the old school method screwdriver in the plug wire, cranked over and looked for an arch. I then checked the wires going to the coil. the pink wire has constant power when ignition is on but the white wire does nothing. From what i read here on the forums it should pulsate when cranking the engine over but does not. Where do i go from here?
Old Feb 18, 2015 | 03:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: help no spark
No spark usually means Bad Coil.
Old Feb 18, 2015 | 04:46 PM
Re: help no spark
ok ill pick one up tomorrow
Old Mar 3, 2015 | 01:44 PM
Re: help no spark
ok finally got around to installing a new distributer, cap, rotor, and module. Still no spark!! Any other suggestions?
Did 87 GTA's come with vats?
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
