Hi beam help
Old Mar 11, 2015 | 03:29 PM
greenfirebird's Avatar
Hi beam help
I can see the rod moving, but it's not moving enough to turn on. Any idea what to do? 92 firebird.
Old Mar 11, 2015 | 04:19 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Hi beam help
Does your car have tilt steering? If so try pulling down on the wheel a bit and pulling the lever. The tilt steering is notoriously bad for either the screws on the hinges coming loose or the pins wearing thru the housing which creates enough slop that the rod doesn't actuate the switch properly. If pulling the wheel down makes the switch work, you have two options: you can simply reposition the switch on the column or you can try and fix the actual cause and tighten up the tilt steering (better, but more difficult).
Old Mar 14, 2015 | 07:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Hi beam help
If the latter:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
327IROC85
Sep 23, 2015 12:11 AM
Fronzizzle
Aug 19, 2015 01:36 PM
