Blower motor fitment
Im installing a 1LE ac delete box on my 91 RS. The box came with a one wire style blower motor (older?) and with this motor it fits perfect in the firewall hole. I swapped the older looking blower for my new 91 blower (2 wire). With the newer motor installed the cage on the motor doesn't line up with the hole in my firewall. Is there a difference between the ac and non ac blower motors??? Could I fix this by simply buying a newer non ac blower?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Blower motor fitment
The "early" style blower motors are specific to AC or non-AC applications and I'm pretty sure they are not compatible. I also recall that the later style blower motors had a 2 wire connector compared to the early style motors with 2 separate power and ground leads.
Don't think that any AC type blower will fit into a non-AC box. I can't recall if the later non-AC blower motors were 2 wire or not, but converting the wiring should be pretty straight-forward........ ( Just Power and Ground )
Car: 87 Iroc Camaro
Engine: 350 Vortec TPI
Transmission: T56 Magnum
Axle/Gears: 10 Bolt 3:73
You can use the AC blower motor in a non AC box, you just have to use a non AC blower wheel. The non AC blower wheel isn't as wide. They are other posts about this subject.
Wow I cant believe I didn't even check that lol. Sure enough I just went out n measured them. Early /non ac-2 3/4", newer w/ac-3 3/4" thank you so much!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A bit late to the party, but perhaps someone else will find the link below useful as there are differences in motors and cages/wheels (note the pics, info and part numbers):
https://www.thirdgen.org/forums/cool...geable-ac.html
JamesC
JamesC
JamesC
JamesC
#PM 102 appears to be the early style motor, with one wire. Im looking for the PN for the later 2 wire plug design. Can someone dig up the PN for a 91 camaro NON ac blower motor
Street Lethal
Aug 13, 2015 08:28 PM
