83 t/a tach not working after cap and rotor changed
Old Mar 26, 2015 | 12:56 PM
freeT/A's Avatar
Car: 1983 T/A ws6
Engine: 5.0l
Transmission: th200c
Axle/Gears: not sure
So I decided to change the cap and rotor on my t/a. Put it all back together and fired it up and noticed my tach is reading 5500rpm. It creeps past 6000 rpm and the just kinda goes where ever it wants. On one note , I never disconnected the battery during the cap and rotor change. Did I fry something?? If I did , where do I start looking?
Old Mar 26, 2015 | 01:13 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 83 t/a tach not working after cap and rotor changed
Old Mar 26, 2015 | 01:18 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
^^^^^^What THAT says! And make sure the 2 wire connector is plugged in and is making a good connection.
Old Mar 26, 2015 | 01:39 PM
freeT/A's Avatar
Car: 1983 T/A ws6
Engine: 5.0l
So the white wire to the distributor is the signal wire for the tach right? And the red wire adjacent to it powers the coil?
Old Mar 26, 2015 | 01:49 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yes, what engine?
5.0 carb:
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
http://www.austinthirdgen.org/?pid=19
Old Mar 26, 2015 | 01:53 PM
freeT/A's Avatar
Car: 1983 T/A ws6
Engine: 5.0l
5.0l carb
Old Mar 26, 2015 | 01:56 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Originally Posted by freeT/A
5.0l carb
http://api.viglink.com/api/click?for...ine_wiring.gif
Old Mar 26, 2015 | 01:57 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Just a quick word of advice.......finish your profile so we all know what your vehicle is.
Old Mar 26, 2015 | 02:01 PM
freeT/A's Avatar
Car: 1983 T/A ws6
Engine: 5.0l
Ok. Well I know where to look...I had those particular connectors apart and back together thinking one of them isnt connecting...so I popped the cap off the coil and pushed the prongs down into the connector to makes sure they didnt get pushed back when I plugged the connectors in. Still no change . Wtf!
Old Mar 26, 2015 | 02:02 PM
freeT/A's Avatar
Car: 1983 T/A ws6
Engine: 5.0l
Ok I will finsh my profile asap!
Old Mar 26, 2015 | 07:32 PM
freeT/A's Avatar
Car: 1983 T/A ws6
Engine: 5.0l
Turns out that I forgot to put the ignition coil strap in . Its in now ,but still the tach is not working. Thinking maybe try a new coil???
Old Apr 8, 2015 | 05:04 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A Tach Plan
If the engine runs you but the tach won’t, it’s not the coils’ fault.
Find out if you’re getting a signal on the
WHITE wire by putting spare marker bulb and speaker in series with the WHITE
wire and ground.
If the
WHITE wire has a signal you will hear it as a buzz that increases with RPM.
Happy Racing !
I Didn’t Jump The Start, The Flagman Was Late
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 7, 2015 04:49 AM
