1984 camaro z28 gauge cluster
Old Mar 29, 2015 | 06:16 PM
blazin38's Avatar
Car: 84 z28 and a 87
Engine: 84 305 and the 87 350 stroker
What gauge cluster will work in my 84 camaro z28 automatic transmission 305???
Old Mar 29, 2015 | 06:27 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1984 camaro z28 gauge cluster
Will work PROPERY = 82-83-84 with V8
Will be accurate for your 84 Z = 84 with V8
Will work but not "plug-&-play" compatible = 85-89 with V8
In 85 the Camaro dash wiring changed and so did the clusters printed circuit. If your 84 used an 85-89 cluster there will be a backlighting & BRAKE warning light problem.
82-83-84 clusters are each "unique" for their year,..... but all (gauge clusters) in that range use the same printed circuit.
Remember: A V6 tachometer is not compatible with a V8 engine. ( check oil pressure gauge: 30/60 = V8 and 40/80 = V6. )
Old Mar 29, 2015 | 06:55 PM
blazin38's Avatar
OK thanks so I have to find an 84 z28 gauge clusters
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
