Wanting To Add Cruse Control: Best Option(s)?
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
1989 Formula; 305 TBI/T5
I'm wanting to add cruise control to my car. Is a factory retrofit, or an aftermarket unit the best way to go?
If it's aftermarket, what are the best ones?
Engine: 4++,350 & 305 CIs
Re: Wanting To Add Cruse Control: Best Option(s)?
Hit up a salvage yard or find someone on here parting a complete car and install all the parts. Its fairly easy to do. Maybe take a day if you have all the stuff
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I have a Audiovox CCS-100 aftermarket cruise control new in the box, I bought it for my Jeep and never got around to installing it. It works with auto or standard trans, hooks up three ways by tach or VSS & tach or with a driveshaft magnet pick-up kit for older cars. Has a small dash mounted control switch, or I was going to get a factory cruise stalk and wire it in.
You can read reviews here; http://www.amazon.com/Audiovox-CCS10...r&pageNumber=1
I'd take $75 shipped......
This is relevant to my interests.
My car seems to have the wiring for CC (a hose coming out of the firewall that hooks to the brake pedal, and a power module.) There's also a black box in the dash that has a pcb on it that I'm not sure what its for. (car also has a separate yellow box which I've heard is for VSS.) Considering the steering column is wired (is it?) I would think all we need is the CC module and the control stick on the column? I'm a long way off from needing this, but if I plan to drive this car more than locally, it'd be something I'd really want ot have.
