Hatch lock
Old Apr 8, 2015 | 09:22 PM
357 Camaro's Avatar
Car: 92 camaro/99 gmc Z71
Engine: 357/5.3
Transmission: built 700r4 4500 stall/4l60
Axle/Gears: 4.56/?
Hatch lock
Hey guys gotta question I hope yall could help with.
I got this car long ago it was striped already of the interior harness I have got most everything hooked back up but after rewiring the hatch motor. I finally have got it workin fine goes up and down pulls the hatch even with the rest of the car.
My problem is I have no key to unlock it I have to get in crawl over the roll cage and use a screw driver to unlock it. I would like to know which wires I use to install to my hatch lock switch to unlock it. I have searched but no luck I find a lot of hatch motor problems but not new wiring for the lock.
Does ne one know which wires I use to run to my switch to unlock the hatch?
Ne help is greatly appreciated and I thank you so much.
Old Apr 9, 2015 | 10:29 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Hatch lock
I don't know what year your car is,.... this diagram is from an 86 IIRC. Pretty sure that most of this wiring was the same for most ThirdGens. ( I think 90+ have most of the wiring included as part of the dash harness,.... earlier cars the wiring was more of an "add on" option. )
Hope this helps !
Old Apr 9, 2015 | 03:19 PM
357 Camaro's Avatar
Engine: 357/5.3
Axle/Gears: 4.56/?
Re: Hatch lock
Ahh so sorry left out the year of my car its 92. I had jus got back from shop and was agrrivated i couldn't figure it our haha. ty so much ill study this.
i know thr harness has 3 blacks red with white stripe and a blacck with orange strip.
Old Apr 9, 2015 | 03:45 PM
John in RI's Avatar
Re: Hatch lock
The 92 style hatch motor was NOT like the diagram above. The one you have is the second style PPD motor that was used for 91 1/2-to-92 cars only.
I don't have that schematic,.... Sorry !
Old Apr 9, 2015 | 09:22 PM
357 Camaro's Avatar
Engine: 357/5.3
Axle/Gears: 4.56/?
Re: Hatch lock
Its ok john I do appreciate your replys and trying to help. Ty a lot I will try and find the diagram for my year you did give me a idea what to look for.
Ty
Old Apr 9, 2015 | 09:40 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Hatch lock
http://www.austinthirdgen.org/mkport..._TAIL_fuse.jpg
http://www.austinthirdgen.org/mkport...onvertible.jpg
http://www.austinthirdgen.org/mkport...wn_release.jpg
Old Apr 10, 2015 | 10:12 AM
357 Camaro's Avatar
Engine: 357/5.3
Axle/Gears: 4.56/?
Re: Hatch lock
Thank you camaro for those links
It seems im confused about the reason that i need a wireto the parkin brake. Does the switch have to have this? The car will have no computer or ne thing of that sort. Does the hatch havt to have this and does ne one have ne pics of this?
sorry bout the stupid questions. Ive had no problem wirin ne of the carto this point and its about all thats left i have jus come to a bump in theroad
Old Apr 10, 2015 | 10:27 AM
Joe Tag's Avatar
Re: Hatch lock
It's wired to the park brake for standards and neutral safety switch for autos. The idea is so you can't pop the hatch accidentally while driving down the road.
Old Apr 10, 2015 | 11:49 AM
357 Camaro's Avatar
Engine: 357/5.3
Axle/Gears: 4.56/?
Re: Hatch lock
Does a b&m megashifter even have a nss? I'm sorry bout the dumb questions so lost haha. Its a auto but has a manual valve body and stuff
Old Apr 10, 2015 | 12:23 PM
Car: 91 z28
Transmission: 4L60e
Re: Hatch lock
Should, looks like a nitrous throttle switch. If not can always be added.
Old Apr 10, 2015 | 08:28 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Hatch lock
I would still replace the hatch lock or have it re-keyed, then hook up the cable from the solenoid hatch release to the back of the lock cylinder.
Lon
Old Apr 11, 2015 | 11:25 AM
357 Camaro's Avatar
Engine: 357/5.3
Axle/Gears: 4.56/?
Re: Hatch lock
After inspecting my shifter more put it on 7 years ago haha. I only have a reverse light switch on it. I looked on the side on my emergency brake it has a prong and it gives me a ground when I pull the brake up. So can I use this?
I noticed on the diagram it has a release switch relay and a extended relay and the hatch solenoid. I only have the extended relay and the solenoid it appears. I was gonna use a momentary push button to release the lock. Will this work or was the hatch lock switch a relay its self? Do I have to buy that if I do where can I?
Lonsal I do believe I am goin to pull the lock and have it rekeyed like u said jus so I have something if I cant get this switch to work .
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
