Side marker wierdness
Old Apr 19, 2015 | 10:29 PM
westido98's Avatar
Car: 1988 Camaro
I have put new bulbs in all but the headlights. Everything works properly except when I turn on the right turn signal. With the right signal on the side marker light on that side goes out. That light only goes out when the right signal is on. What could be in the issue?
Old Apr 20, 2015 | 04:53 AM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: Side marker wierdness
The front turn signal and side marker will flash opposite of each other. If the front if off the side will be on, when the front is on the side will be off. This is a normal function of the circuit.
Old Apr 20, 2015 | 02:19 PM
westido98's Avatar
Car: 1988 Camaro
The driver side marker and signal flash at the same time. I'm thinking it's the sign of an issue because the right doesn't flash whether it's the dash light or the outside lights (probably should've put that last part in the original post lol)
Old Apr 20, 2015 | 10:44 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
With the headlight switch off, the front turn signal and the marker light flash simultaneously.
With the headlight switch on (either park or head), the front turn signal and the marker light flash alternately.
Which position is the headlight switch when the marker light doesn't flash?
Depending on whether the headlight switch is on or off determines where the marker light gets its ground.
Old Apr 21, 2015 | 06:00 PM
westido98's Avatar
Car: 1988 Camaro
When the headlights are on and the right signal is on the marker is off and the lights don't flash. When the headlights are off and the signal is on the marker is on but the lights do not flash. I have also just last night replaced the turn signal switch.
Old Apr 21, 2015 | 06:43 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
The one common denominator is that the signals don't flash. It sounds like you have a bad flasher.
How do the lights behave when you turn on the hazard flashers?
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
