lights issue 87 t/a
Old Apr 23, 2015 | 11:47 PM
z+k's Avatar
z+k
Car: 2014 cruze and 1987 trans am
Engine: trans am=5.0
Transmission: auto
lights issue 87 t/a
upon replacing a light bulb in my tail light,an issue arose. as i was unscrewing the light bulb( or thought i was) the glass separated from the metal piece that goes in the connector, the bulb started to gather smoke and after i was finally able to get it out all the way none of the tailights worked, none of the dash lights work now either, it would appear that just the turn signals works( turning on the turn signal causes the tailights to flash for a turn). ive started checking fuses but if anyone has any insight on this it would be appreciated. ill be checking all of the fuses tomorrow and will post an update then.
Old Apr 26, 2015 | 09:02 PM
z+k's Avatar
z+k
Transmission: auto
Re: lights issue 87 t/a
the fuse was the issue and has been replaced, i have also replaced my rear tailights with nicer ones and replaced all of the light bulbs with new ones. problem now is the not all the light bulbs seem to come on. there is some gunk on the inside where the contacts are, i cleaned most of it out and still not all of the lights turn on. any ideas or suggestions would be appreciated.
Frozer!!!
Jan 19, 2024 04:55 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
