Wont start!
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
Wont start!
Im working on my wifes 91 z28 350 tpi...I changed the valve covers now the car wont start...turn the key it does nothing I hear the fuel pump come on and hear clicking under the hood but when you turn the key nothing NO draw even with the headlights on I checked power by the starter the bigger terminal has power im guessing the little wire is from the ignition switch has no power when key is on...Any ideas on where I can start to get this back up and running...Thanks...
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Not Cranky . . . . SO I AM !!!!!!
Use voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the wire going to the solenoid power input.
Make the wire long enuff to bring into the cockpit.
Now, when you try to crank, is there power?
If yes, the solenoid is bad.
Happy Racing !
Whether It’s A Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
Happy Racing !
92camaroJoe
Aug 13, 2015 06:07 AM
