elec fuel pump and ecm
Old May 11, 2015 | 02:42 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
I bought a 1987 Iroc roller that has the elec fuel pump. I took the complete drive train out of my 1987 coupe and installed in this car. ( 350 carbed motor and 700r4 trans) I want to keep the elec fuel pump, I know it works. My questions are (1) I want to remove the ecm, looking at the existing harness where it goes thru the passenger fender and under the dash there are only 3 wire's, black, blue and green. Can I just unplug this connecter and leave ecm under dash or is there more I have to remove ? (2) I was tracing the harness to the ecm and found several places where the previous owner had cut and spliced wire's ( hack job) so I am thinking I can just remove the complete harness from the engine compartment and install the harness from the 87 Camaro sport coupe I took the motor and trans from. everything worked as it should in the coupe.(3) The other question is can I just get power for the fuel pump relay from the fuse panel for the switched 12v and install a fused wire to the battery for the constant 12 volts to the relay. I know just enough about elec to be dangerous so any help would be great.
Thanks Ron
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
