Dash lights aren't working. Checked fuse and replaced dimmer.
Old Jun 20, 2015 | 08:53 PM
WalkingBread's Avatar
As titled the cluster lights are not working in my 92 camaro. I replaced the fuse and the headlight dimmer switch. I get check enigine and other lights but nothing for the gauges.. the pigtail for the dimmer switch was melted a little. I tested the pigtails for power and seemed operational. Headlights work. My only conclusion is that something has to be wrong with the wiring. I have no idea where to trace it back to, not possible to visually trace it.
Also I have a problem wiring my stereo. I'm not getting power to the ignition 12v. No key required to start my camaro. So I'm assuming there is something wrong with the ignition itself.
I bought the car from a kid who did god knows what to it. I've wired the fan to a toggle already.. and I've taken out more wiring than Ive put in.
Thanks for any input you have on either of my problems!
Old Jun 29, 2015 | 07:05 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 Cash
Make sure the dash dimmer control is set at the bright position, then using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe BOTH sides of the INST LPS fuse.
If there is no power both sides check for power on the
orange wire at the headlight switch.
Then check for power on the
dark green wire at the headlight switch.
Is there power on both wires?
Happy Racing !
The Steering Turns Real Easy When The Car Is On The Roof
Old Jun 30, 2015 | 11:51 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: Dash lights aren't working. Checked fuse and replaced dimmer.
On my '87 trans am, there was a transistor attached to an aluminum heat sink near the convenience center (the cluster of relays, flashers, and chimes above the driver's right knee). That transistor took the signal from the dimmer wheel and controlled the dash lights. I had to replace it a couple times.
Old Jun 30, 2015 | 01:47 PM
NINÅ's Avatar
Transmission: 765R4
Dash 4 Cash
Fortunately his car has no transistor in the circuit.
Happy Racing !
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
