86 trans am t5 reverse lights and neutral safety
Old Jun 21, 2015 | 07:27 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
one of the many small things that needs fixed on my trans am is the fact that the reverse lights dont work. When i first got the car it would turn over just fine. then as we started to plug everything up under the dash after swapping some components out it seemed you had to play with the clutch pedal a little to get it to turn over. this eventually ended up not starting at all. So i browsed the internet for a little and found out about the plug under the center console that has the neutral safety switch and reverse lights in it. So i got a jumper wire and jumped the neutral safety wires and it starts up all the time, the reverse lights light up if i jump those wires. So my question is that does this plug plug into. the transmission had the shifter swapped out for a short shifter and im almost certain this car is originally a t5
Old Jun 21, 2015 | 08:42 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
Re: 86 trans am t5 reverse lights and neutral safety
I interested in this thread cause my reverse light are inop also
Old Jun 23, 2015 | 06:07 AM
The reverse light switch is in the driver's side of the transmission case. The plug that goes into it has a blue and a green wire.
Old Jun 23, 2015 | 07:55 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
I know where the reverse switch is at on the transmission, my question is what plugs into the harness under the center console to complete the circuit for the reverse and neutral safety switch, thanks for the response though
Old Jun 23, 2015 | 08:16 PM
Sorry, I guess I'm stupid, I thought you were asking what the reverse light wires plug into. Which I agree is pretty hard to believe, is the reverse light switch.
That wiring is not in the center console in a stick car. So the answer to that would be, nothing.
The plug that goes into the transmission has a blue and a green wire. Find such a plug and plug it in. If your harness doesn't have it (comes out of the engine harness near the distributor) then you can make some kind of an extension for the wires you DO have and route them to the trans .... somehow.
Old Jun 23, 2015 | 09:00 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Ok I'll have to try and trace it tomorrow, so is the wiring the same for a stick and auto car since mine has the plug under the center console, if so I guess that would be explain why the car would start without that being plugged in
Old Jun 27, 2015 | 11:32 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your not stupid,... you just don't know it all.
Firebird does NOT = Camaro. Unlike the Camaros; the Firebird dash harnesses in 86 is factory wired for both automatic and stick cars. (FYI: many/most pre-88 stick cars have the reverse light wiring located in the ECM harness C207 or C221 connector. )
The NSS plug in your center console shouldn't plug into anything if the car is a stick. By jumping the wires on the center consoles' auto plug your simply bypassing the T5 wiring and using the auto wiring. My guess is that the reverse switch on the side of the T5 is going bad ( pretty common failure after 25+ years. ) and I'd take a good look at the clutch switch plug on the pedal to be sure that it can engage properly. I don't recall what type of switch was used in 86 for the clutch pedal,... there were 2 designs and the earlier style ( Rod type ) was prone to failure compared to the later " button" style.
Old Jun 27, 2015 | 12:08 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Yea the nss is the rod style, good to know that they were wired for both so I'm not continuing to look at where this connector would have plugged into. Thanks for your help
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
