Rat infested Camaro Nightmare
Old Jul 6, 2015 | 07:31 PM
rode1951's Avatar
Car: 84 Camaro
Engine: 632 hp 434
Axle/Gears: 3.90
I'm restoring this 89 Camaro 2.8 for my neighbor kid. I unplugged the EST bypass to set the timing. When I did the fuel pump died. Did I burn out the relay? Should I have shut the car down before unplugging it?
Old Jul 8, 2015 | 07:27 PM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Re: Rat infested Camaro Nightmare
Yes you should have started the car, let it warm up. Cut it off, diconnect the plug then start it again. Now with a light, set the timing to desired degrees, cut car off, connect plug again. Start car to verify it's running good. That's the procedure for setting base timing.
Old Jul 8, 2015 | 09:47 PM
rode1951's Avatar
Car: 84 Camaro
Engine: 632 hp 434
Axle/Gears: 3.90
Thanks, some useful info. Now please help me to get the pump to restart, the pump is new, the fuse is good, and I replaced the relay, but no pump yet.
Old Jul 13, 2015 | 05:04 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fixing His rat Motor
To test the relay and pump simultaneously use a spare piece of wire and jump the orange wire to the green wire with the white stripe.
What happens when you do that?
Happy Racing !
“Professional Maniac Operating, Do Not Drive 330 MPH In Your Own Home”
Old Jul 13, 2015 | 05:42 PM
rode1951's Avatar
Car: 84 Camaro
Engine: 632 hp 434
Axle/Gears: 3.90
Thank you very much, I'll give it a try. Unfortunately I'm in the hospital right now, but should get out tomorrow, and will get on it ASAP
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
