Possibly ignition switch?
Old Jul 21, 2015 | 07:03 PM
1985chevydude's Avatar
Car: 1985 chevy camaro,z28
Engine: crate 350,headers,3in exhaust
Axle/Gears: 308------3.73 auburn unit
Hello everyone.
As the past few months have worn on ive been haveing to turn the key to start the car a few times before the starter even engages.
For example ill pump the gas for the carb in my 85 z and turn the key all the way to start yet nothing will happen.
Once i back the key off and try again it starts.
Any ideas from what ive read on our forum it may be an ignition switch so i purchased one.
Id like some feed back to see if anyone has had this issue i didnt read this exact problem but similar so i thought id clarify thank you
Old Jul 22, 2015 | 06:53 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Possibly ignition switch?
Had a similar issue on my Formula. Sometimes would catch, other times wouldn't until the key cylinder froze altogether and wouldn't move at all. Replaced the ignition key cylinder and haven't had a problem since. When I removed the old cylinder you could see visible damage from wear and tear. Good luck.
Old Apr 6, 2016 | 08:39 AM
I just saw this thanks for the answer were did you find the cylinder and is this a nightmare to fix?
Old Apr 7, 2016 | 02:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Do you have a tilt column by chance?
Old Apr 7, 2016 | 02:55 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
It can be a bit of a pain getting everything off the column to get to the cylinder, but certainly doable at home. If you do end up changing it out, I highly recommend one of these tools for depressing the locking ring:
May not be a bad ignition cylinder though, so best try and determine what is causing the issue before tearing apart the column.
Old Apr 7, 2016 | 03:02 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If it's what I think it is, it's not the switch.
Old Apr 9, 2016 | 07:59 PM
Yes it is a tilt Colum car and when I move the wheel around it starts fie and then it acts up again.
Old Apr 9, 2016 | 08:03 PM
I believe your right because I changed the ignition switch and I still have this issue. I hate these tilt Colum cars. It seems maybe an issue with the two rods or something.
Old Apr 9, 2016 | 09:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
This is the part that was giving me grief.Thats was over 10 yrs ago.Had to visit the JY to score one.
This illustration even mentions it.Thats exactly where mine cracked.Theres a rod in that slot that moves back/forth with the key turning.Its actuates the switch at the bottom of the column.
What happened with mine was the rod was slipping thru the crack, instead of moving bk/forth.Its a pretty involved job, but I got it done w/out a manual back then.So its not impossible.
Old Apr 11, 2016 | 07:17 PM
someone972's Avatar
Engine: 5.7L TPI
If it is actually that piece, or the black gear shown in the image, you can get a Dorman replacement at Orielly's and likely other places. Something you might want to try is pulling the wheel down and to the left when turning the key and see if it changes anything. I don't remember if worn tilt affects the ignition switch; it definitely affects the high beam switch.
Old Apr 11, 2016 | 10:30 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The gear is plastic I believe & attaches to the flat stub on the end of the ign cylinder.That rack is made of potmetal.I was able to "bandaid" fix mine by zapping it with my welder, it worked, but first chance I got I replaced it.
I could get mine to work sometimes by tilting down the wheel.This was due to the crack located slightly above center.The rack pivots with the upper portion of the tilt column.So adjusting the wheel down put the crack higher in relation to the actuating rod.This kept the rod from slipping thru the crack & the engine would fire up.
Old Apr 15, 2016 | 07:56 PM
That would make sense!
now as for the ignition switch i changed those are already pre adjusted right?
my dad said that it might need adjusting but i thought it already is/I really appreciate the help you guys are awesome!!!!!!!!!!
Old Apr 15, 2016 | 08:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I don't know of adjustment required.It basically only goes in one way.
Old May 3, 2016 | 09:26 AM
I appreciate the help. I guess ill just wait until the car doesn't start at all.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
