1984 High Output Owners Help Please!
Old Jul 25, 2015 | 04:34 PM
zachariahZ28's Avatar
Car: 1984 camaro Z28 H.O
Engine: 5.0 H.O
Hello Everyone, i recently swapped my old engine from my 84 Z, but when i was doing so i also took off all the wire harnesses, from the firewall to the ecm through the fender. My question is has anyone done this before and rewired the new camaro with no issues? i have majority of the wire hooked up but im not getting power from the battery passed the alt. I had originally took pictures but do to lack of communication ALL of my notes and pictures of removing the harness is lost can someone please possible show me or tell me what wires lead to the starter, alt, and distributor? i have tried searching numerous times for these things but i end up finding different wire diagrams its hard for me to know which one belongs to a 1984 Z28 H.O its a 5.0 5speed.
Any feed back would be much appreciated, thanks for reading
Old Jul 25, 2015 | 07:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 1984 High Output Owners Help Please!
http://www.austinthirdgen.org/?pid=19
Alternately, these are for 86, 84 should be same/similar...
Attached Thumbnails 1984 High Output Owners Help Please!-86_alt.gif   1984 High Output Owners Help Please!-86_dist.gif   1984 High Output Owners Help Please!-86_start.gif
Old Jul 26, 2015 | 08:33 AM
Should be a harness going over the bell housing flange starting at the bulkhead connector under the brake booster and passing under the dist; at the far end should be a purple wire with a small ring terminal and some red wires with large rings. Purple goes to S terminal of starter solenoid; large ones go to the stud on the solenoid w the batt cable.
The ECM harness is not involved with any of that in any manner way shape or form.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
