Help
Help
Ihave a 1992 Camaro and the other day I was installing a replacement stereo system and then I heard a pop then I stop getting power through my orange battery wire and yellow ignition wire please any ideas
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Help
Did you check the fuse box? Any fuses blown? If not, possibly a fusible link.
Re: Help
Check all of your fuses. Check them good too.
The orange wire should be powered by a 20 amp fuse. The yellow should be from that 10 amp radio fuse. I find it hard to believe that fuse is good.
