1990,1991,1992 Camaro Tach Fix
Old Aug 25, 2015 | 12:01 PM
Armored91Camaro's Avatar
Car: 1992 Camaro RS Heritage Edition
Engine: LO3 305 5.0L v8
Axle/Gears: 10 Bolt Factory 2.73 Open
Here is an old thread i created a few years back when i needed to fix mine. Keep in mind i have a v6, but should be the same for a v8.
http://camaroforums.com/forum/82-92-...-raitos-70327/
Aight last night August 19, 2012 i took the board out of the cluster that controls the Tach Gauge, there is a lil black and white resistor chip on the board. I followed a thread on another forum and measured my resistance.
My resistance between pins 4 and 10 was 299-300. The actual resistance should be around 200 give or take,. I purchased a Actron Multimeter that reads engine RPMs and pluged up the RED lead to the DIST and the BLACK lead to the body. I also purchased a potentiometer 1meg ohm. Soldered to pins 4 and 10 on the chip, then matched the resistance that the tach needed to match as close to the Actron device as possible. 200rpm on the actron is 2,000rpm.
In all i have learned that sometimes whats wrong with the car is just a loose nut behind the wheel that can't leave anything alone lol. here are some pictures maybe this will help others out.
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
