VATS
Old Oct 7, 2015 | 08:26 PM
Poncho92's Avatar
VATS
Stupid question what is it and whats it do
Old Oct 7, 2015 | 08:33 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: VATS
Vehicle Anti-Theft System. It prevents auto theft by disabling the starter and the injectors if the incorrect key is used in the ignition switch.
Old Oct 7, 2015 | 08:53 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: VATS
I found this about VATS =
Description of VATS:
VATS is a General Motors (GM) security system that has a resistor embedded in the blade
of the key. There are 15 different resistors in the single sided configuration, and 14
different resistors in the double sided configuration. There is a three minute penalty for
using the incorrect resistor.
Normal operation is for the key, with resistor pellet, to be inserted and turned. If the correct
resistance is read, the VATS Module, through a relay, will allow the starter to crank the
engine and also send a signal to the ECM to allow the operation of the fuel injectors.
Without the correct resistor the injectors and starter are inhibited.
The security derives from the fact that there is a one-in-fourteen / fifteen chance of having
the correct resistor. The worst case scenario when the penalty is invoked (3 x 15) is 45
minutes. This discourages, but does not eliminate, the theft of the vehicle.
MSRed91Camaro
Oct 6, 2015 01:56 PM
J.C. Denton
Sep 21, 2015 04:23 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
92rsvortec350
Sep 10, 2015 10:54 AM
