Mystery pictures Name that part 2
Old Nov 11, 2015 | 06:08 PM
sharlimar's Avatar
Car: The Car-1990 Camaro RS Coupe
Engine: 5.0 Litre
Transmission: standard
Axle/Gears: single axle 5 speed
Do any of you know what this harness is for, called (so I can try to look it up), what should plug into it? Maybe this one doesn't connect at all-could be from something someone changed long ago. This is on a 1990 Camaro RS. The harness is below the dash, driver side, above the clutch pedal , to the right of the fuse block-to the left of the steering column & hi/low selector. Thank you.
Attached Thumbnails Mystery pictures Name that part 2-100_0769.jpg   Mystery pictures Name that part 2-100_0770.jpg
Old Nov 11, 2015 | 06:12 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Mystery pictures Name that part 2
Nothing plugs into that , that is your "diagnostic connector" (OBD1 connector) and is used to read the codes from the ECM during troubleshooting ..
Old Nov 11, 2015 | 07:30 PM
sharlimar's Avatar
Engine: 5.0 Litre
Thank you. Do you know if I leave this "post/tread" open or how I take care of it now that there is an answer?
Old Nov 12, 2015 | 05:20 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
There is no open or closed. It'll just sit here.
NAWTDADZ
Dec 18, 2025 11:08 AM
John Hagan
Dec 16, 2024 07:39 PM
JHutch440
Oct 26, 2015 10:35 PM
Dee555
Oct 20, 2015 10:55 AM
anesthes
Oct 15, 2015 07:44 AM
