Headlight Module issues...
Old Nov 11, 2015 | 06:45 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
Hello, I have read info on here about the 87-89 headlight modules and the 90-92(2002) modules not interchanging. My '87 has a bad module(have to tap it to work). I have 2 90 modules from boneyard. Has anyone played with the wiring or know of a thread i can read where someone put a later on in an 87-89? I mean there is the option to take mine apart and check solder joints... I also took austin's wiring diagrams and mirrored them. the only difference in wiring i see is the wiring to the light motors. In relation to the wires coming out of the module, the wires are reversed where the lettered designation is. any ideas?
Old Nov 17, 2015 | 01:03 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Re: Headlight Module issues...
Now that I have a little time, i'm going to play around with the module/motor setup. my theory is if i'm at the yard and find a module and motors from a parts car, about $40, i can bolt it up and it should work like a 90-92. Just make sure the wiring is routed the same out of the switch/fuse. then the wiring to the motors needs to be correct out of the module in relation to the pin locations. The reason i'm doing this is they changed the design for a reason, i'm assuming it's a more reliable part. i'll post back results.
Old Nov 17, 2015 | 02:02 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
It might not be the module. I had a similar issue and swapped out my module but still had the issue on occasion. Long story short, the issue was not the module. It was the wire harness plugging into the module. It was old and needed to be jiggled to make the module work. I replaced the plug and haven't had the issue return.
Old Nov 17, 2015 | 03:08 PM
Johnny*G's Avatar
Car: 1987 Trans Am
ah i missed a step in the KISS method! thank you! i will gently wiggle each wire individually. My initial test was a light tap on the module. But that could be masking a loose wire connection. I'll report back...
Old Jan 7, 2016 | 07:31 PM
Johnny*G's Avatar
Car: 1987 Trans Am
FIXED! Re: Headlight Module issues...
ok, so after a few other issues i've been sorting out, i finally got back to this issue. I want to thank all the suggestions!!! I did find a loose connection at the module connector. I simply took a pick and tightened the female ends and havn't had the problem. Thanks again!!!
Old Jan 8, 2016 | 07:01 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Yes. Start easy and work up. I fiddled with mine too for ages before finding a bad ground wire near the battery. Several things suddenly worked again after fixing it.
Old May 24, 2016 | 12:23 PM
Johnny*G's Avatar
Car: 1987 Trans Am
still have trouble with the connection at the module. i wonder if it's a loose pin at the module? i'm gonna try pinching the connectors again.
GeneralIesrussi
Jan 22, 2018 01:19 AM
Drone358
Jan 16, 2016 07:48 AM
90formulaVortec
Nov 9, 2015 05:07 PM
Cleotiz
Nov 7, 2015 07:11 AM
Gambit TA
Nov 7, 2015 03:37 AM
