No warning lights
Old Dec 27, 2015 | 08:58 PM
Jacques101's Avatar
Car: 1984 &1987 Firebird, 1991 GTA
Engine: 5.0(84) , 5.7L LT1 (87),5.0(91)
Transmission: Automatic
Axle/Gears: 3.23;3.42;2.73
No warning lights
Ok - need some help on this '84 Firebird. None of the engine warning lights on the dash are coming on. No Check Engine, Park brake , etc... I pulled the cluster and replaced all the lights. Lights are functional, but when you turn on the ignition, none of the check/ warning lights comes on. Car starts and runs fine. Any ideas?
Old Dec 28, 2015 | 08:53 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Warning System Failed Without Warning
When you turn the key to the START position do any of the gages peg?
If no, check for a broken ground connection at the ignition switch.
Happy Racing !
If You’re In Front Of Me DON’T Slam On Your Brakes Just Because Someone At The Head Of The Pack Is Spinning
Old Dec 29, 2015 | 06:36 PM
Jacques101's Avatar
Re: No warning lights
The only gauge that really pegs is the temperature gage… I also noticed when I had the cluster out… I traced the track for the check engine light… And when I turned in the ignition to the on position, that terminal went from 0 to 0.64 V…
Old Dec 30, 2015 | 02:03 PM
NINÅ's Avatar
Transmission: 765R4
OK because the temp gage pegs we know that one ignition switch ground is good.
During engine start the Airbag Lamp is illuminated VIA the Airbag Module.
During engine start the Security Lamp is illuminated VIA the VATS module.
The Brake Warning Lamp is illuminated VIA another wafer in the ignition switch.
The SES Lamp is illuminated VIA the ECM.
The Seat Belt lamp is illuminated VIA the Audio Alarm Assembly located in the ‘Convenience Center’, which is to the right of the steering column.
Make sure both fuses, the GAGES fuse and the INST LPS fuse are good.
The balance of the lamps are not supposed to illuminate at engine start.
Happy Racing !
Old Dec 30, 2015 | 06:18 PM
Jacques101's Avatar
New warning light module and all is up and running.... Thanks for all the help!
Old Jan 20, 2018 | 06:53 PM
necrobird's Avatar
what is a warning light module and where does it go?
Old Jan 20, 2018 | 10:48 PM
Jacques101's Avatar
https://rover.ebay.com/rover/0/0/0?m...2F192429422098It is located in a little green box on the rhs. I believe it was either taped to the harness close to the ecm or it was underneath the trim panel on the dashboard below the map pocket where the rear window defrost relay is located This is on a ‘84 Firebird
OldMan89
Sep 7, 2023 01:44 AM
GMan 3MT
Jul 23, 2016 10:39 PM
ndndndnd
Dec 30, 2015 01:13 PM
jorgeblancojr
Dec 11, 2015 11:33 PM
wolftamer389
Brakes
Dec 11, 2015 08:56 PM
