Gauge cluster
Old Feb 15, 2016 | 07:55 PM
Peter1970's Avatar
Gauge cluster
How can I bench test A 1987 Trans Am electronic Gauge cluster My speedometer is not working And I'm not sure if the sending unit is working either Everything from the cluster works except for the speedometer They no longer fabricate and I cannot find the sending unit for a T5 So before I purchase A GPS sending unit I just want to test the speedometer to see if it actually working
Old Feb 15, 2016 | 09:14 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Gauge cluster
You can fill out your car details and possibly a location here.
Check the vss connector for voltage with key on.
Then if wire A has +5v, plug it back in and check wire B with a tachometer while the car is on stands, running some speed.
If bad, mech speedo gears and a thread-on VSS like Jags That Run sells will work. You'll need the 4004 pulse/mile version.
https://www.thirdgen.org/forums/tran...-vss-help.html
Ninety-One
Brakes
Apr 10, 2016 11:25 PM
Johnny*G
Mar 25, 2016 07:33 PM
turd_gen
Feb 22, 2016 10:17 AM
82Brlinetta
Feb 14, 2016 08:53 PM
1991z28camaro
Jan 31, 2016 01:06 PM
