1982 Z/28 Speedometer trouble
Car: 1982 Camaro z28
Engine: 305 CFI
Transmission: 200M
Hello, I'm having trouble with my 1982 Camaro Z/28 speedometer the problem is, it stopped working. I believe i've narrowed it down to the speedometer itself but i'm not totally sure. I've replaced the gear in the transmission and have even changed the cruise control unit. I have had the speedometer pegged many times while driving. I am wondering if I have striped the head of the speedometer, or perhaps something is bound up in the cable. The car only has a little over 59,000 on it and I would like to keep it as original as I can.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1982 Z/28 Speedometer trouble
probably just a broken or disengaged cable-you cannot damage the speedo by pegging it-needle is moved by a spinning magnet causing "eddy current "drag on aluminum drum attached to needle.If odometer not turning there is no drive to speedo.
Engine: 305 CFI
Transmission: 200M
Yes the odometer is not working, thank you for your help! I'm relieved that's all it is, I hope.
Phtjp
Feb 9, 2016 04:08 PM
ev305tpi
Feb 4, 2016 08:40 PM
