Fog Light Relay Replacement?
Old Feb 18, 2016 | 10:12 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Now that most of my drivability issues are resolved, I'm determined to get the foglights working.
Doing some troubleshooting, and it appears that the foglight relay, after carefully pulling it apart, is a mass of rusted components, and needs to be replaced.
The relay says it's a Bosch, P/N 25525638.
This part seems to have been discontinued, and a search on several sites come up pretty empty on what actually fits the connector properly, and is an equivalent to the original Bosch relay.
What are you that have had to replace this relay using?
Old Feb 18, 2016 | 01:00 PM
Car: 1988 IROC-Z
Re: Fog Light Relay Replacement?
I sprayed the thing like there was no tomorrow with WD-40...after whacking it a few times, the foglights came on.
Noticed the adjuster for the passenger side light is broken, and the screw doesn't fit on the collar..are the adjusters different on foglights, compared to the standard ones used on our headlights?
pshat
Sep 20, 2017 01:56 PM
transaero
Jan 10, 2017 09:24 PM
92tealZconv
Feb 23, 2016 02:31 PM
82Brlinetta
Feb 14, 2016 08:53 PM
ChrisMPG
Feb 13, 2016 11:03 PM
