soo car wont shut off unless...
Old Feb 27, 2016 | 12:18 PM
oBEA5To's Avatar
Car: 1984 camaro
Engine: 305 carbed
Transmission: automatic
So here my problem i have a 84 camaro 305 my key got stuck in the lock position a few weeks back so i replaced the cylinder an it works!! Until now.. Now i put the key in to start the car it wont spring back from the crank position so i have to do it and when i go to turn the key off it wont turn off unless the steering wheel is all the way down. Basically the cylinder moves freely when cars running and wont shut it off. Any ideas?
Old Mar 1, 2016 | 02:29 PM
edweiser's Avatar
Car: 1989 camaro rs
Engine: 305 ci
Transmission: auto
Re: soo car wont shut off unless...
i am, or thought i was, a pround new owner of a new project car. 1989 camaro rs. 305 engine, auto tranny. instrument cluster was a mess, with guages not working and a noisy speedo. figured id take everything apart, clean connections and replace a few bulbs as well as the tach. wired up the aftermarket stereo correctly and now the car wont start. have feul and spark at the coil. am i missing something? anyone with some insight would be greatly appreciated. thanks
Old Mar 1, 2016 | 02:55 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
edweiser make a new thread for your separate issue
Old Mar 1, 2016 | 05:59 PM
edweiser's Avatar
Car: 1989 camaro rs
Engine: 305 ci
Transmission: auto
thanks for your input. however, i am new to the forums of any sort. feel stupid asking, but can anyone help a guy navigate forums?
Old Mar 1, 2016 | 06:05 PM
thtanner's Avatar
Here's the link to post a New Topic in the Electronics forum.
https://www.thirdgen.org/forums/newt...newthread&f=11
This will make a new thread for you separate from this one. This will allow the people to respond direct to your issue instead of potentially confusing it with the poster of this topic.
Old Mar 2, 2016 | 09:04 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Sounds like you'll have to take the column back apart. Neither the ignition switch nor the lock cylinder are spring loaded. Take the wheel back off and see where the cylinder fits in the actuator and if it is not in correctly or if something is broken. Good luck!
ev305tpi
Feb 4, 2016 08:40 PM
steve's Z28
Jan 30, 2016 11:48 PM
gresmi
Jan 25, 2016 05:40 PM
newagereject
Jan 25, 2016 01:36 AM
Ryder249
Jan 19, 2016 03:39 PM
